Short/long press detection #
You can detect whether a short or long press was performed and implement different behaviors.
Create a resident script with 0 sleep time,
modify the timeout and mapping variables as needed.
Default long press time is 1 seconds.
In this example there are two input objects - 32/1/1 and 32/1/4.
If 32/1/1 is pressed and released within 1 second then
32/1/2 (short press) value is toggled. Otherwise 32/1/3
(long press) value is toggled if the button is not released
within 1 second.
if not client then
timeout = 1 -- long press in seconds
mapping = {
['32/1/1'] = { short = '32/1/2', long = '32/1/3' },
['32/1/4'] = { short = '32/1/5', long = '32/1/6' },
timerstep = timeout / 4
function eventhandler(event)
local object = mapping[ event.dst ]
if not object then
return
local value = busdatatype.decode(event.datahex, dt.bool)
if value then
object.timer = timeout
elseif object.timer then
object.timer = nil
grp.write(object.short, not grp.getvalue(object.short), dt.bool)
client = require('localbus').new(1)
clientfd = socket.fdmaskset(client:getfd(), 'r')
client:sethandler('groupwrite', eventhandler)
timer = require('timerfd').new(timerstep)
timerfd = socket.fdmaskset(timer:getfd(), 'r')
res, clientstat, timerstat = socket.selectfds(10, clientfd, timerfd)
if clientstat then
client:step()
if timerstat then
timer:read()
for addr, object in pairs(mapping) do
object.timer = object.timer - timerstep
if object.timer <= 0 then
object.timer = nil
grp.write(object.long, not grp.getvalue(object.long), dt.bool)
