Partition wall light control #
Task #
Create a script that controls lights in all rooms where the partition walls are not closed from any switch that is located in these rooms. It's a universal solution that works for any number of partition walls with a limit of one switch / light per room.
Event script #
All input objects should have a common tag to which this event script is attached.
Modify inputs (push-buttons), sensors (true when the wall is closed)
and outputs (lights) tables as needed.
Number of inputs and outputs should match and the number of sensors should be one less.
inputs = {
'33/1/1',
'33/1/2',
'33/1/3',
'33/1/4',
'33/1/5',
sensors = {
'33/2/1',
'33/2/2',
'33/2/3',
'33/2/4',
outputs = {
'33/3/1',
'33/3/2',
'33/3/3',
'33/3/4',
'33/3/5',
value = event.getvalue()
for i, addr in ipairs(inputs) do
if addr == event.dst then
index = i
grp.write(outputs[ index ], value)
for i = index, #sensors do
if grp.getvalue(sensors[ i ]) then
break
grp.write(outputs[ i + 1 ], value)
for i = index - 1, 1, -1 do
break
grp.write(outputs[ i ], value)
Further assistance can be found in this forum thread
