On/off delay timer #
Create a resident script with 0 sleep time. Modify the timers table as needed.
Each table key is an input group address (1/1/1 and 1/1/3 in this example).
Each table value is a table containing output group address,
ON delay (delayon) and OFF delay (delayoff) values in seconds.
Sending the same ON or OFF value several times does not restart the timer.
if not client then
timers = {
['1/1/1'] = {
output = '1/1/2', -- binary output
delayon = 10, -- on delay time (seconds)
delayoff = 0, -- off delay time (seconds)
['1/1/3'] = {
output = '1/1/4', -- binary output
delayon = 40, -- on delay time (seconds)
delayoff = 60, -- off delay time (seconds)
grp.sender = 'tm'
function set(timer)
grp.checkwrite(timer.output, timer.state == 'on')
timer.state = nil
timer.ticks = nil
client = require('localbus').new(0.1)
client:sethandler('groupwrite', function(event)
local timer = timers[ event.dst ]
if timer and event.sender ~= grp.sender then
local value = tonumber(event.datahex, 16) or 0
local state = value > 0 and 'on' or 'off'
if timer.state ~= state then
timer.state = state
local ticks = timer['delay' .. state]
if ticks > 0 then
timer.ticks = ticks
set(timer)
end)
client:loop(1)
for _, timer in pairs(timers) do
if timer.ticks then
timer.ticks = timer.ticks - 1
if timer.ticks == 0 then
set(timer)
